[mapguide][MG333][Modified] Drawing Data resource schema validation allows empty Coordin...
Steve Dang steve.dang at autodesk.com
Fri Oct 20 19:35:09 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG333
Type:
Defect
Artifact ID:
MG333 (Drawing Data resource schema validation allows empty Coordinate System tags)
Modified by:
Steve Dang
stevedang (steve.dang at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG435 (Undo changes made in artifact MG333)
Modified
File: trunk/MgDev/Common/Schema/DrawingSource-1.0.0.xsd https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Schema/DrawingSource-1.0.0.xsd?view=diff&rev=926&p1=trunk/MgDev/Common/Schema/DrawingSource-1.0.0.xsd&r1=925&p2=trunk/MgDev/Common/Schema/DrawingSource-1.0.0.xsd&r2=926
File: trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd?view=diff&rev=926&p1=trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd&r1=925&p2=trunk/MgDev/Common/Schema/FeatureSource-1.0.0.xsd&r2=926
File: trunk/MgDev/Common/Schema/LoadProcedure-1.0.0.xsd https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Schema/LoadProcedure-1.0.0.xsd?view=diff&rev=926&p1=trunk/MgDev/Common/Schema/LoadProcedure-1.0.0.xsd&r1=925&p2=trunk/MgDev/Common/Schema/LoadProcedure-1.0.0.xsd&r2=926
File: trunk/MgDev/Common/Schema/MapDefinition-1.0.0.xsd https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Schema/MapDefinition-1.0.0.xsd?view=diff&rev=926&p1=trunk/MgDev/Common/Schema/MapDefinition-1.0.0.xsd&r1=925&p2=trunk/MgDev/Common/Schema/MapDefinition-1.0.0.xsd&r2=926
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
