[mapguide][MG376][Modified] Point reference not correctly read when OS uses "," for deci...
Tom Fukushima tom.fukushima at autodesk.com
Sat Oct 21 18:43:22 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG376
Type:
Defect
Artifact ID:
MG376 (Point reference not correctly read when OS uses "," for decimal)
Modified by:
Tom Fukushima
tomfukushima (tom.fukushima at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG376 Set the server to the "C" locale so that "." is always interpreted to be decimals.
Added
File: trunk/MgDev/Common/Foundation/System/SetLocale.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/System/SetLocale.cpp?view=auto&rev=927
File: trunk/MgDev/Common/Foundation/System/SetLocale.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/System/SetLocale.h?view=auto&rev=927
Modified
File: trunk/MgDev/Common/Foundation/Foundation.vcproj https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/Foundation.vcproj?view=diff&rev=927&p1=trunk/MgDev/Common/Foundation/Foundation.vcproj&r1=926&p2=trunk/MgDev/Common/Foundation/Foundation.vcproj&r2=927
File: trunk/MgDev/Common/Foundation/FoundationBuild.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/FoundationBuild.cpp?view=diff&rev=927&p1=trunk/MgDev/Common/Foundation/FoundationBuild.cpp&r1=926&p2=trunk/MgDev/Common/Foundation/FoundationBuild.cpp&r2=927
File: trunk/MgDev/Common/Foundation/Makefile.am https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/Makefile.am?view=diff&rev=927&p1=trunk/MgDev/Common/Foundation/Makefile.am&r1=926&p2=trunk/MgDev/Common/Foundation/Makefile.am&r2=927
File: trunk/MgDev/Common/Foundation/System/Util.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Foundation/System/Util.cpp?view=diff&rev=927&p1=trunk/MgDev/Common/Foundation/System/Util.cpp&r1=926&p2=trunk/MgDev/Common/Foundation/System/Util.cpp&r2=927
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
