[mapguide][MG376][Modified] Point reference not correctly read when OS uses "," for deci...
Tom Fukushima tom.fukushima at autodesk.com
Sat Oct 21 18:49:19 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG376
Type:
Defect
Artifact ID:
MG376 (Point reference not correctly read when OS uses "," for decimal)
Modified by:
Tom Fukushima
tomfukushima (tom.fukushima at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG376 Set the server to the "C" locale so that "." is always interpreted to be decimals.
Modified
File: trunk/MgDev/Server/src/Core/main.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Core/main.cpp?view=diff&rev=928&p1=trunk/MgDev/Server/src/Core/main.cpp&r1=927&p2=trunk/MgDev/Server/src/Core/main.cpp&r2=928
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
