[mapguide][MG430][Modified] Labels for point symbols with off-center insertion point dra...
Jason Nogar jason.nogar at autodesk.com
Wed Oct 25 16:11:56 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG430
Type:
Defect
Artifact ID:
MG430 (Labels for point symbols with off-center insertion point draw wrong)
Modified by:
Jason Nogar
jasonnogar (jason.nogar at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
Update to MG430 fix: one bit mask was missing in the overpost location calculation, which resulted in an overflow of the overpost array for angles near 360 degrees.  The complex expression to modulate the rotation angle has also been replaced with a much simpler call to fmod.
Modified
File: trunk/MgDev/Common/Stylization/PointAdapter.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/PointAdapter.cpp?view=diff&rev=941&p1=trunk/MgDev/Common/Stylization/PointAdapter.cpp&r1=940&p2=trunk/MgDev/Common/Stylization/PointAdapter.cpp&r2=941
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
