[mapguide][MG398][Modified] WMS GetFeature doesn't support SRS parameter (only CRS)
Chris Claydon
chris.claydon at autodesk.com
Tue Sep 19 18:16:42 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG398
Type:
Defect
Artifact ID:
MG398 (WMS GetFeature doesn't support SRS parameter (only CRS))
Modified by:
Chris Claydon
chrisclaydon (chris.claydon at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- Status Explanation set to new value:
Fixed in trunk. Awaiting approval to fix in SP1 stream.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
