[mapguide][MG399][New] GetSpatialContexts returning NULL extent
Tony Fang
tony.fang at autodesk.com
Tue Sep 19 19:09:34 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG399
Type
Defect
Artifact ID
MG399 (GetSpatialContexts returning NULL extent)
Reported by
Tony Fang
tfang (tony.fang at autodesk.com)
New artifact details:
- Version set to new value
1.0.1
- Priority set to new value
P1
- Summary set to new value
- Steps to Reproduce set to new value
Using Studio:
1. create a Load Procedure
2. select one of the SDF files from the UnitTestDataFiles (XYGridSdfV2pt1.sdf, XYGridSdfV3pt0.sdf, or XYGridSdfV3pt0_NoWKT.sdf used by the BroadFastVerify tests)
3. set Generalization to 50%
4. create the Load Procedure
5. open up the newly created Layer Definition
6. Notice the mgserver.exe crash!!!
- Subcomponent set to new value
Feature Service
- Artifact created
- Defect Severity set to new value
High
- Component set to new value
Server
- Description set to new value
GetSpatialContexts is returning a NULL extent, which cannot be handled by the server. IT causes the server to crash when it attempts to serialize the NULL extent.
- Artifact Status set to new value
New
- Platform set to new value
All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
