[mapguide][MG400][New] MgFeatureService::GetRaster parameter should be CREFSTRING i...
Bruce Jia bruce.jia at autodesk.com
Wed Sep 20 03:10:11 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG400
Type
 Defect
Artifact ID
 MG400 (MgFeatureService::GetRaster parameter should be CREFSTRING instead of STRING)
Reported by
 Bruce Jia
 brucejia (bruce.jia at autodesk.com)
New artifact details:
- Component set to new value
  Server
- Artifact created
- Artifact Status set to new value
  New
- Priority set to new value
  P3
- Description set to new value
  MgFeatureService::GetRaster parameter should be CREFSTRING instead of STRING. This minor error caused SWIG failed to generate wrapper for it.
- Summary set to new value
- Subcomponent set to new value
  Feature Service
- Steps to Reproduce set to new value
  View the source code.
- Version set to new value
  1.0.1
- Defect Severity set to new value
  Medium
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
