[mapguide-users] ODBC problem...
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Tue Apr 11 12:31:24 EDT 2006
Ya, I've tried both methods too (DSN and Connection Strings)....same
problem either way.
Joel Carranza wrote:
> I don't think that the project is just with Jet connections. I have
> been unable to get any kind of ODBC (access, Oracle ODBC) connection
> to work, resulting in an identical error. I get similar results using
> either the Data Source Name or Connection String options
> Joel Carranza
> jec at gatekeeper.com
> Gatekeeper Systems
> Andrew DeMerchant wrote:
>> I've just installed the latest Mapguide, Mapserver, and Studio as
>> well as the ODBC and Raster providers. Everything working fine,
>> except the ODBC. I've got a Jet connection set up on my computer, and
>> the provider does find it...I select the data source name, save the
>> connection, and then try "Test Connection" and get some errors:
>> System.Net.WebException: The remote server returned an error: (559)
>> MgFdoException.
>> at
>> Autodesk.MapGuide.Studio.Site.Comm.RequestManager.ExecutePendingGetRequestToString(Operation
>> operation)
>> at
>> Autodesk.MapGuide.Studio.Site.Comm.RequestManager.TestConnection(String
>> resourceId, String provider, String connectionString)
>> at Autodesk.MapGuide.Studio.Site.FeatureSourceInfo.TestConnection()
>> at
>> Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.TestConnectionControl.buttonTestConnection_Click(Object
>> sender, EventArgs e)
>> Am I missing something here, or does it just not yet work with Jet
>> databases? My data source is totally fine, as it works with other web
>> apps that I have made.
>> Andrew
>> ps - Great work on the Raster provider!
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.506-453-1025
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
*Andrew DeMerchant*
ph.506-453-1025
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users
