Failed to test the Web Server Extensions after installation
Francisco Javier Rojas Duran
francisco.rojas at dasoft.com.mx
Tue Apr 11 13:08:23 EDT 2006
Remember with Java , Apache is registered as service but NO TOMCAT , you
should start tomcat manually from Program
Files/MapGuideOpenSource/WebExtensions/Tomcat/bin. Remember you must have
JAVA_HOME environmet variable already configured and JDK 1.5.0_06 installed.
Every time after Apache has started, you must start TOMCAT.
If that doesnt works look for httpd.conf and the JKMod Tomcat Conector for
Apache2
Best Regards.
CSE Francisco Javier Rojas Durán
IT Manager - Oracle Specialist
Division de Tecnologias de Información
Grupo DaSoft S.A. de C.V.
_____
De: Yi Liang [mailto:yiliang2008 at gmail.com]
Enviado el: Martes, 11 de Abril de 2006 08:19 a.m.
Para: users at mapguide.osgeo.org
Asunto: Failed to test the Web Server Extensions after installation
Hello,
I installed the MapGuide server and extenstion v1.0.0 according to the
manual, selecting the following options:
java development
when checking the installation using:
http://localhost/mapguide/mapviewerajax/ajaxviewer.jsp?WEBLAYOUT=Library://A
Test.WebLayout
The browser displays the content of file ajaxviewer.jsp, it should be
"Resource was not found: Library://ATest.WebLayout"
It seems something wrong with Tomcat.
Any help appreciated.
Y.L.
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060411/bc6b0267/attachment.html
More information about the Mapguide_users
