[mapguide-users] Problems with selection
Andy Morsell amorsell at spatialgis.com
Thu Apr 20 13:16:15 EDT 2006
I am seeing the same thing in regards to the joined feature (polygons joined
to Access) not highlighting when selected but the attributes do show up in
the Properties pane.  I am also seeing some general weirdness with this
layer.  If I turn it off in the legend, it does not turn off on the map (a
request to the server does not occur) until I select an object.  Panning and
zooming aren't forcing the refresh.  I suspect these are related issues and
the refresh flag is getting stuck when interacting with these types of
layers.
I don't see the same thing as you in the second case.  If I select an object
and it highlights and then turn off that layer, the highlight turns off as
well.  When that layer is turned back on, the highlight also reappears.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Thursday, April 20, 2006 9:36 AM
Subject: RE: [mapguide-users] Problems with selection
Some more observations...
It seems that when I select my parcel layer that is tied to my Access
database, the highlight feature doesn't work.  When I switch over to use
just the layer that is based strictly on the sdf file, the highlighting
works.  So I guess it has something to do with layers that are tied to an
Access database.  Can someone else please try this and let me know if they
are seeing this?
Also, when I select a feature and then turn of the layer of the selected
feature, the feature seems to still be selected.  Odd.
FYI: I'm using the AJAXViewer
- Juan
  _____
Sent: Thu 4/20/2006 12:05 PM
Subject: [mapguide-users] Problems with selection
Has anyone experienced problems with features not highlighting after
selection?  The data appears in the Properties frame, but the feature isn't
highlighted.  Plus, the bottom of the map states 1 feature selected.  It's
only on my parcel polygon layer.   My other polygon layers select and
highlight fine.  Weird.
Another thing I noticed was when I had a feature selected from this layer,
if I go to zoom out or pan, the map locks up and does nothing unless I
unselect the feature.
- Juan
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060420/ab42bf16/attachment.html
More information about the Mapguide_users mailing list
