[mapguide-users] Tiled map using GETMAPIMAGE
sukalyan chakraborty chakraborty.sarkar at gmail.com
Sat Apr 22 01:10:31 EDT 2006
No i'm In version Framework 1.1 .. is there any requirement to run this in
framework 2.0?
Please inform me with some detailed help..
On 4/21/06, Butler, Juan P <jpbutler at co.pinellas.fl.us> wrote:
>  You need to make sure that you are using .NET Framework 2.0.   Go into
> IIS and check to see if the virtual directory for the application is using
> 2.0.
> Juan Butler - Senior Programmer/Analyst
> GIS Applications
> Pinellas County Information Systems
> jpbutler at pinellascounty.org
> *From:* sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
> *Sent:* Friday, April 21, 2006 8:18 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] Tiled map using GETMAPIMAGE
> *Compiler Error Message: *CS0246: The type or namespace name 'OSGeo' could
> not be found (are you missing a using directive or an assembly reference?)
> *Source Error:*
> Line 16:
> Line 17: <%@ Page language="c#" %>
> Line 18: <%@ Import Namespace="OSGeo.MapGuide" %>
> Line 19: <!-- #Include File="utilityfunctions.aspx" -->
> On 4/19/06, *velen* <vliang at thecarbonproject.com> wrote:
> Hello,
> We were able to generate tiled map using GETMAPIMAGE from a .net windows
> form; below is the screen shot. As you can see, in the sample Sheboygan map,
> some "District" numbers were chopped off in the same tile or showed in the
> adjacent tiles. I understood this is probably because each tile get rendered
> individually, but is there a solution for making tiles look likes what
> ajaxviewer does?
> Thanks for your help in advance,
> Velen
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060422/8cfdfdf0/attachment.html
More information about the Mapguide_users mailing list
