[mapguide-users] Tiled map using GETMAPIMAGE
Butler, Juan P
jpbutler at co.pinellas.fl.us
Sat Apr 22 15:56:53 EDT 2006
Yes. You need .NET framework 2.0 for the .NET version of Open Source.
- Juan
From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
Sent: Sat 4/22/2006 1:10 AM
Subject: Re: [mapguide-users] Tiled map using GETMAPIMAGE
No i'm In version Framework 1.1 .. is there any requirement to run this in framework 2.0?
Please inform me with some detailed help..
On 4/21/06, Butler, Juan P <jpbutler at co.pinellas.fl.us> wrote:
You need to make sure that you are using .NET Framework 2.0. Go into IIS and check to see if the virtual directory for the application is using 2.0.
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
From: sukalyan chakraborty [mailto: chakraborty.sarkar at gmail.com]
Sent: Friday, April 21, 2006 8:18 AM
Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could not be found (are you missing a using directive or an assembly reference?)
Source Error:
Line 16:
Line 17: <%@ Page language="c#" %>
Line 18: <%@ Import Namespace="
OSGeo.MapGuide" %>
Line 19: <!-- #Include File="utilityfunctions.aspx" -->
On 4/19/06, velen < vliang at thecarbonproject.com <mailto:vliang at thecarbonproject.com> > wrote:
Hello,
We were able to generate tiled map using GETMAPIMAGE from a .net windows form; below is the screen shot. As you can see, in the sample Sheboygan map, some "District" numbers were chopped off in the same tile or showed in the adjacent tiles. I understood this is probably because each tile get rendered individually, but is there a solution for making tiles look likes what ajaxviewer does?
Thanks for your help in advance,
Velen
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060422/2de89fb8/attachment.html
More information about the Mapguide_users
