[mapguide-users] Problem with MsSQL Server
Robert Fortin
robert.fortin at autodesk.com
Tue Aug 1 19:51:10 EDT 2006
Manuel,
Was there log result provided by bulk copy?
If not set the environment variable FDO_TRACE_FILE to a file name and
rerun your test.
There should info in the trace file which help you track the problem.
My guess is that it is a privilege on the datastore where you are
copying your data.
RF
-----Original Message-----
From: Manuel Salazar [mailto:manuel.salazar at joflansys.com.mx]
Sent: Tuesday, August 01, 2006 7:43 PM
Subject: [mapguide-users] Problem with MsSQL Server
Hi everybody,
we are using Map 3D 2007 (SP1, SP2) to load and write data, and we have
a problem when we made a bulk copy between any provider to MS SQL Server
2000 SP4.
Error "Bad parameter to method"
Any idea.
Thanks
Manuel Salazar
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
