[mapguide-users] No Feature Providers in Studio Preview
Marcus Spurkel
mspurkel at pacbell.net
Tue Aug 1 21:59:50 EDT 2006
Well it's Fedora, so I installed an rpm. Version is 5.0.18. I'll check
the dependencies, but is it really necessary to get so low-level that I
have to edit the providers.xml file by hand? Not that I mind (I'm a
programmer after all) but I would have thought that MapGuide would have
some sort of higher level and/or GUI-based interface for setting up data
connections. Or at the very least, shouldn't the fdo make process have
detected my MySQL installation and taken care of it?
Traian Stanev wrote:
>I think those two are special cased to not show up in that list, but I'm not sure. I'd start by adding MySQL to providers.xml on the server. Then make sure the MySQL provider .so is not missing any dependencies (use ldd or something) and restart the server process. Did you compile the MySQL provider yourself, and if yes, what source code are you working with (what date?)
> -----Original Message-----
> From: Marcus Spurkel [mailto:mspurkel at pacbell.net]
> Sent: Tue 8/1/2006 9:25 PM
> To: users at mapguide.osgeo.org
> Cc:
> Subject: Re: [mapguide-users] No Feature Providers in Studio Preview
> Yeah, that works. And you're right: my providers.xml file only mentions
> SDF and SHP. So:
> 1. Why don't those two show up on the Data Connection popup winodow as
> feature providers?
> 2. How can I get MySQL (which I do have on the server) to show? Do need
> to go back and recompile fdo with a certain switch?
> Remember I'm on FC5, not Windows. I found some references to API
> discussions but I'm not sure that's what I need. I just want to start
> by setting up a connection path.
> -Marcus
> >You probably have only the SHP and SDF providers on your Liunx box, so you see nothing on that list in Studio. Simply drag an SHP or SDF file into Studio (into the tree view on the left) and see what happens.
> >Traian
> > Sent: Tue 8/1/2006 7:17 PM
> > Cc:
> > Subject: [mapguide-users] No Feature Providers in Studio Preview
> > I just tried clicking on New|Data Connection... in Studio 2007 Preview
> > and got an empty popup, i.e. no feature providers listed. I do have a
> > providers.xml file in my FDO install directory (and the server admin
> > does point to the correct place) but for some reason it's not seeing
> > it. Does anyone know what's wrong? I'm running on a Linux box (FC5).
> > -Marcus
> > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > For additional commands, e-mail: users-help at mapguide.osgeo.org
> >No virus found in this incoming message.
> >Checked by AVG Free Edition.
> >Version: 7.1.394 / Virus Database: 268.10.5/404 - Release Date: 7/31/2006
More information about the Mapguide_users
