[mapguide-users] No Feature Providers in Studio Preview
Traian Stanev traian.stanev at autodesk.com
Tue Aug 1 21:42:11 EDT 2006
I think those two are special cased to not show up in that list, but I'm not sure. I'd start by adding MySQL to providers.xml on the server. Then make sure the MySQL provider .so is not missing any dependencies (use ldd or something) and restart the server process. Did you compile the MySQL provider yourself, and if yes, what source code are you working with (what date?)
	-----Original Message-----
	From: Marcus Spurkel [mailto:mspurkel at pacbell.net]
	Sent: Tue 8/1/2006 9:25 PM
	Cc:
	Subject: Re: [mapguide-users] No Feature Providers in Studio Preview
	Yeah, that works.  And you're right: my providers.xml file only mentions
	SDF and SHP.  So:
	1. Why don't those two show up on the Data Connection popup winodow as
	feature providers?
	2. How can I get MySQL (which I do have on the server) to show?  Do need
	to go back and recompile fdo with a certain switch?
	Remember I'm on FC5, not Windows.  I found some references to API
	discussions but I'm not sure that's what I need.  I just want to start
	by setting up a connection path.
	-Marcus
	Traian Stanev wrote:
	>You probably have only the SHP and SDF providers on your Liunx box, so you see nothing on that list in Studio. Simply drag an SHP or SDF file into Studio (into the tree view on the left) and see what happens.
	>Traian
	>       Sent: Tue 8/1/2006 7:17 PM
	>       Cc:
	>       Subject: [mapguide-users] No Feature Providers in Studio Preview
	>       I just tried clicking on New|Data Connection... in Studio 2007 Preview
	>       and got an empty popup, i.e. no feature providers listed.  I do have a
	>       providers.xml file in my FDO install directory (and the server admin
	>       does point to the correct place) but for some reason it's not seeing
	>       it.  Does anyone know what's wrong?  I'm running on a Linux box (FC5).
	>       -Marcus
	>       To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
	>       For additional commands, e-mail: users-help at mapguide.osgeo.org
	>No virus found in this incoming message.
	>Checked by AVG Free Edition.
	>Version: 7.1.394 / Virus Database: 268.10.5/404 - Release Date: 7/31/2006
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060801/44db6f62/attachment.bin
More information about the Mapguide_users mailing list
