[mapguide-users] No Feature Providers in Studio Preview
Traian Stanev
traian.stanev at autodesk.com
Wed Aug 2 09:19:21 EDT 2006
An rpm of the provider or the MySQL database? Do you have libFdoMySQL in
the directory where FDO is?
There is an install script for FDO providers that also adds to the xml
file automatically, but since I don't know what exactly you did, it was
easiest to go for the manual way.
-----Original Message-----
From: Marcus Spurkel [mailto:mspurkel at pacbell.net]
Sent: Tuesday, August 01, 2006 10:00 PM
Subject: Re: [mapguide-users] No Feature Providers in Studio Preview
Well it's Fedora, so I installed an rpm. Version is 5.0.18. I'll check
the dependencies, but is it really necessary to get so low-level that I
have to edit the providers.xml file by hand? Not that I mind (I'm a
programmer after all) but I would have thought that MapGuide would have
some sort of higher level and/or GUI-based interface for setting up data
connections. Or at the very least, shouldn't the fdo make process have
detected my MySQL installation and taken care of it?
Traian Stanev wrote:
>I think those two are special cased to not show up in that list, but
I'm not sure. I'd start by adding MySQL to providers.xml on the server.
Then make sure the MySQL provider .so is not missing any dependencies
(use ldd or something) and restart the server process. Did you compile
the MySQL provider yourself, and if yes, what source code are you
working with (what date?)
> Sent: Tue 8/1/2006 9:25 PM
> Cc:
Preview
> Yeah, that works. And you're right: my providers.xml file only
mentions
> SDF and SHP. So:
> 1. Why don't those two show up on the Data Connection popup
winodow as
> feature providers?
> 2. How can I get MySQL (which I do have on the server) to show?
Do need
> to go back and recompile fdo with a certain switch?
> Remember I'm on FC5, not Windows. I found some references to
API
> discussions but I'm not sure that's what I need. I just want to
start
> by setting up a connection path.
> -Marcus
> >You probably have only the SHP and SDF providers on your Liunx
box, so you see nothing on that list in Studio. Simply drag an SHP or
SDF file into Studio (into the tree view on the left) and see what
happens.
> >Traian
> > Sent: Tue 8/1/2006 7:17 PM
> > Cc:
> > Subject: [mapguide-users] No Feature Providers in Studio
Preview
> > I just tried clicking on New|Data Connection... in
Studio 2007 Preview
> > and got an empty popup, i.e. no feature providers
listed. I do have a
> > providers.xml file in my FDO install directory (and the
server admin
> > does point to the correct place) but for some reason
it's not seeing
> > it. Does anyone know what's wrong? I'm running on a
Linux box (FC5).
> > -Marcus
> > To unsubscribe, e-mail:
users-unsubscribe at mapguide.osgeo.org
> > For additional commands, e-mail:
users-help at mapguide.osgeo.org
> >To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> >For additional commands, e-mail: users-help at mapguide.osgeo.org
> >No virus found in this incoming message.
> >Checked by AVG Free Edition.
> >Version: 7.1.394 / Virus Database: 268.10.5/404 - Release Date:
7/31/2006
7/31/2006
More information about the Mapguide_users
