[mapguide-users] No Feature Providers in Studio Preview
Marcus Spurkel mspurkel at pacbell.net
Wed Aug 2 13:22:19 EDT 2006
The rpm is for the MySQL database (as well ad the devel & client
modules).  I definitely do not have a libFdoMySQL.so file (or anything
close to it) in my fdo directory.  I checked the /providers directory in
the fdo source and there is nothing there that looks like it could be
related either.  Originally, I simply ran build_linux.sh from fdo source
and everything got built automatically.
Hmmm, I did just come across this in the online version of the
OpenSourceBuild_README file which, for some reason, was not in the tarball:
NOTE: Choosing the RPM install of the MySQL components is *strongly*
recommended. However, if a non-RPM installation of MySQL is chosen,
following the installation, set the following FDO environment variable:
FDOMYSQL=[MySQL developer components path]
I never set an FDO environment variable, though judging by the text I
shouldn't have to since I did use RPMs.  Still...
I also did a grep scan of all Makefile and configure files and found no
references to MySQL whatsoever.  What am I missing here?
-Marcus
Traian Stanev wrote:
>An rpm of the provider or the MySQL database? Do you have libFdoMySQL in
>the directory where FDO is?
>There is an install script for FDO providers that also adds to the xml
>file automatically, but since I don't know what exactly you did, it was
>easiest to go for the manual way.
>-----Original Message-----
>From: Marcus Spurkel [mailto:mspurkel at pacbell.net]
>Sent: Tuesday, August 01, 2006 10:00 PM
>To: users at mapguide.osgeo.org
>Subject: Re: [mapguide-users] No Feature Providers in Studio Preview
>Well it's Fedora, so I installed an rpm.  Version is 5.0.18.  I'll check
>the dependencies, but is it really necessary to get so low-level that I
>have to edit the providers.xml file by hand?  Not that I mind (I'm a
>programmer after all) but I would have thought that MapGuide would have
>some sort of higher level and/or GUI-based interface for setting up data
>connections.  Or at the very least, shouldn't the fdo make process have
>detected my MySQL installation and taken care of it?
>>I think those two are special cased to not show up in that list, but
>I'm not sure. I'd start by adding MySQL to providers.xml on the server.
>Then make sure the MySQL provider .so is not missing any dependencies
>(use ldd or something) and restart the server process. Did you compile
>the MySQL provider yourself, and if yes, what source code are you
>working with (what date?)
>>	Sent: Tue 8/1/2006 9:25 PM
>>	Cc:
>Preview
>>	Yeah, that works.  And you're right: my providers.xml file only
>mentions
>>	SDF and SHP.  So:
>>	1. Why don't those two show up on the Data Connection popup
>winodow as
>>	feature providers?
>>	2. How can I get MySQL (which I do have on the server) to show?
>Do need
>>	to go back and recompile fdo with a certain switch?
>>	Remember I'm on FC5, not Windows.  I found some references to
>API
>>	discussions but I'm not sure that's what I need.  I just want to
>start
>>	by setting up a connection path.
>>	-Marcus
>>	>You probably have only the SHP and SDF providers on your Liunx
>box, so you see nothing on that list in Studio. Simply drag an SHP or
>SDF file into Studio (into the tree view on the left) and see what
>happens.
>>	>Traian
>>	>       Sent: Tue 8/1/2006 7:17 PM
>>	>       Cc:
>>	>       Subject: [mapguide-users] No Feature Providers in Studio
>Preview
>>	>       I just tried clicking on New|Data Connection... in
>Studio 2007 Preview
>>	>       and got an empty popup, i.e. no feature providers
>listed.  I do have a
>>	>       providers.xml file in my FDO install directory (and the
>server admin
>>	>       does point to the correct place) but for some reason
>it's not seeing
>>	>       it.  Does anyone know what's wrong?  I'm running on a
>Linux box (FC5).
>>	>       -Marcus
>>	>       To unsubscribe, e-mail:
>users-unsubscribe at mapguide.osgeo.org
>>	>       For additional commands, e-mail:
>users-help at mapguide.osgeo.org
>>	>To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>	>For additional commands, e-mail: users-help at mapguide.osgeo.org
>>	>No virus found in this incoming message.
>>	>Checked by AVG Free Edition.
>>	>Version: 7.1.394 / Virus Database: 268.10.5/404 - Release Date:
>7/31/2006
>7/31/2006
More information about the Mapguide_users mailing list
