[mapguide-users] Join Features
Dave Wilson dave.wilson at autodesk.com
Thu Aug 3 10:14:28 EDT 2006
Assuming you have actually checked various properties to be displayed in
the layer definition the most common problem for not seeing properties
is not recognizing what mode the viewer is in. Often times you need to
ensure you are in select mode (click the arrow icon in either viewer
toolbar) to ensure you are in select mode. Sometimes you can be in pan
or zoom mode and selection just doesn't work in these modes.
Otherwise as far as I know selection should work on a join.
Dave
-----Original Message-----
From: farzad ghavam [mailto:ensejam at ns1.tak-host.com] On Behalf Of
farzad ghavam
Sent: Thursday, August 03, 2006 12:45 AM
Subject: RE: [mapguide-users] Join Features
thanks Dave,
I can view the data by new feature class and create a web layout, but
now I can't select any polygon of this layer for view that properties.
also sometimes in dwf viewer this layer hasn't any data,do you know
why?(just DWF, AJAX is right)
farzad.
> In the layer you must change your feature class to the new one
defined
> in the join. You should then see the property list change to show the
> additional columns.
> Leave the geometry as the orginal geometry property for the SDF. If
you
> select the new geometry you will get nothing.
> Dave
>   _____
> From: Farzad Ghavam [mailto:farzadghavam at yahoo.co.uk]
> Sent: Wednesday, August 02, 2006 7:02 AM
> Subject: [mapguide-users] Join Features
> Hi to all,
> I'm sorry for my english,
> I have a problem with Join Feature section by following steps:
>    1-Load a SDF file and create a layer by this ( Named : WorldSDF )
>    2-create a new connection with ODBC-Table in an Access DB file (
> Named : WorldDB ) and get 'Successful connection' message after test
> connection.
>    3-in 'Join with other feature sources(optional)' create a new
> extended feature class and connect 'WorldSDF' and 'WorldDB' by those
> fileds.
>    4-create a layer by new feature class ( NewLayer ) but when
preview
> ,there isn't any data
> please help me.
> thanks
> farzad
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
