[mapguide-users] Join Features
Bogdan Modzelewski Bogdan.Modzelewski at procad.pl
Fri Aug 4 05:22:32 EDT 2006
Hello,
> Assuming you have actually checked various properties to be displayed in
> the layer definition the most common problem for not seeing properties
> is not recognizing what mode the viewer is in. Often times you need to
> ensure you are in select mode (click the arrow icon in either viewer
> toolbar) to ensure you are in select mode. Sometimes you can be in pan
> or zoom mode and selection just doesn't work in these modes.
Unfortunately problem lies somewhere else. I've the same problem with
join to PostgreSQL database (described in "SDF & Postgres Join problem"
thread).
It's not just select/zoom mode mistake, but IMO bug in server code.
Previously, I've thought that there is a bug in OGR FDO provider, but
Farzad uses AccessDB, so probably bug is in server side.
MG developers, could you check it, please?
> Dave
Best Regards,
Bogdan Modzelewski
> -----Original Message-----
> From: farzad ghavam [mailto:ensejam at ns1.tak-host.com] On Behalf Of
> farzad ghavam
> Sent: Thursday, August 03, 2006 12:45 AM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] Join Features
> thanks Dave,
> I can view the data by new feature class and create a web layout, but
> now I can't select any polygon of this layer for view that properties.
> also sometimes in dwf viewer this layer hasn't any data,do you know
> why?(just DWF, AJAX is right)
> farzad.
More information about the Mapguide_users mailing list
