[mapguide-users] OGR with postgis support
Traian Stanev
traian.stanev at autodesk.com
Mon Aug 14 09:07:42 EDT 2006
You don't need to do in in Studio. Just adding it to providers.xml on
the server is enough. Then in Studio go to New Data Connection and you
will see the provider on the list.
Traian
-----Original Message-----
From: Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
Sent: Monday, August 14, 2006 3:11 AM
Subject: Re: [mapguide-users] OGR with postgis support
You must edit providers.xml and copy the dll into the FDO directory.
This must be done in both the Service FDO folder and the Studio FDO
folder.
I'm guessing that Studio uses the GUI part, and the Service does the
actual data access.
Perhaps Studio should be modified to load this from the server?
But then there would be windows/linux problems.
I don't know how this works in Web Studio, if thats what you are trying.
Mvh. Kenneth, GEOGRAF A/S
kenny at keniginc.com skrev:
> Ok,
> I know I have been a bit slower catching on to this than most, largely
> because other extreme commitments but please bear with me.
> I just downloaded, unzipped and compiled OGR Provider with PostGIS
> support so I can gain direct access to some of our files using
> connections.
> After adding an entry to providers.xml, I restarted service, wen to
> studio and database connection but it isn't there.
> What am I doing wrong?
> Thanks very much in advance
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
