[mapguide-users] OGR with postgis support
kenny at keniginc.com kenny at keniginc.com
Mon Aug 14 09:24:39 EDT 2006
I have already added the ODBC provider to providers.xml and I can see
it in Studio.
However, it works with MS Access but throws an error when I attempt to
connect it to SQL Server db.
Quoting Traian Stanev <traian.stanev at autodesk.com>:
> You don't need to do in in Studio. Just adding it to providers.xml on
> the server is enough. Then in Studio go to New Data Connection and you
> will see the provider on the list.
> Traian
> -----Original Message-----
> From: Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
> Sent: Monday, August 14, 2006 3:11 AM
> To: users at mapguide.osgeo.org
> Subject: Re: [mapguide-users] OGR with postgis support
> You must edit providers.xml and copy the dll into the FDO directory.
> This must be done in both the Service FDO folder and the Studio FDO
> folder.
> I'm guessing that Studio uses the GUI part, and the Service does the
> actual data access.
> Perhaps Studio should be modified to load this from the server?
> But then there would be windows/linux problems.
> I don't know how this works in Web Studio, if thats what you are trying.
> Mvh. Kenneth, GEOGRAF A/S
> kenny at keniginc.com skrev:
>> Ok,
>> I know I have been a bit slower catching on to this than most, largely
>> because other extreme commitments but please bear with me.
>> I just downloaded, unzipped and compiled OGR Provider with PostGIS
>> support so I can gain direct access to some of our files using
>> connections.
>> After adding an entry to providers.xml, I restarted service, wen to
>> studio and database connection but it isn't there.
>> What am I doing wrong?
>> Thanks very much in advance
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
