[mapguide-users] OGR with postgis support
Kenneth, GEOGRAF A/S
ks at geograf.dk
Mon Aug 14 09:09:03 EDT 2006
I haven't tried anything using SQL server, but I can't imagine that
there should any problems when connecting through ODBC.
Mvh. Kenneth, GEOGRAF A/S
kenny at keniginc.com skrev:
> Thanks very much, Kenneth!
> I got it now.
> Just one related question. Are we still unable to connect to sql
> server db using ODBC?
> Quoting "Kenneth, GEOGRAF A/S" <ks at geograf.dk>:
>> There is an FDO folder for Studio in C:\Program
>> Files\Autodesk\MapGuideStudio2007\FDO.
>> There is an FDO folder for MgServer in C:\Program
>> Files\Autodesk\MapGuideEnterprise2007\Server\Bin\FDO.
>> Correct the above paths to your system.
>> You must copy the OGRProvider.dll to both folders above, and edit the
>> providers.xml in both folders.
>> If you use MapGuide OS, it has recently shifted to FDO 3.2, and you
>> have to change the version number in providers.xml.
>> If you use MapGuide EP, you must build OGR provider, using an older FDO
>> snapshot, otherwise it won't load.
>> After restarting the service and studio, you should be able to select
>> New -> Data connection...
>> On the list you should now see "OSGeo FDO Provider for OGR"
>> I hope you are working on windows, as you will have to compile a
>> .dll/.so for both windows and linux otherwise.
>>> Hi Kenneth and thank you for responding to this thread.
>>> How do you edit the providers.xml?
>>> It is my understanding that from the readme associated with the ogr
>>> provider that I downloaded that you need to do 2 things:
>>> 1, add an entry, this entry:
>>> <FeatureProvider>
>>> <Name>OSGeo.OGR.0.1</Name>
>>> <DisplayName>FDO Provider for OGR</DisplayName>
>>> <Description>Access to OGR data sources</Description>
>>> <IsManaged>False</IsManaged>
>>> <Version>0.1.0.0</Version>
>>> <FeatureDataObjectsVersion>3.1.0.0</FeatureDataObjectsVersion>
>>> <LibraryPath>OGRProvider.dll</LibraryPath>
>>> </FeatureProvider>
>>> to providers.xml and as you correctly stated, add the OGRprover.dll
>>> into FDO.
>>> I have done these and restarted the mapGuide service.
>>> If all goes well, when you go to Studio and attempt to add a
>>> database connection, you should the OGR provider. Right now, I only
>>> see the ODBC connection that I set up awhile back.
>>> Did I miss something?
>>>> You must edit providers.xml and copy the dll into the FDO directory.
>>>> This must be done in both the Service FDO folder and the Studio FDO
>>>> folder.
>>>> I'm guessing that Studio uses the GUI part, and the Service does the
>>>> actual data access.
>>>> Perhaps Studio should be modified to load this from the server?
>>>> But then there would be windows/linux problems.
>>>> I don't know how this works in Web Studio, if thats what you are
>>>> trying.
>>>>> Ok,
>>>>> I know I have been a bit slower catching on to this than most,
>>>>> largely because other extreme commitments but please bear with me.
>>>>> I just downloaded, unzipped and compiled OGR Provider with
>>>>> PostGIS support so I can gain direct access to some of our files
>>>>> using connections.
>>>>> After adding an entry to providers.xml, I restarted service, wen
>>>>> to studio and database connection but it isn't there.
>>>>> What am I doing wrong?
>>>>> Thanks very much in advance
>>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
