[mapguide-users] OGR with postgis support
kenny at keniginc.com
Thu Aug 17 10:12:00 EDT 2006
Guys,
I have tried to use the OGR Provider and it isn't working.
I am attaching a screenshot. Is it supposed to look like this?
Quoting "Kenneth, GEOGRAF A/S" <ks at geograf.dk>:
> I haven't tried anything using SQL server, but I can't imagine that
> there should any problems when connecting through ODBC.
> Mvh. Kenneth, GEOGRAF A/S
> kenny at keniginc.com skrev:
>> Thanks very much, Kenneth!
>> I got it now.
>> Just one related question. Are we still unable to connect to sql
>> server db using ODBC?
>>> There is an FDO folder for Studio in C:\Program
>>> Files\Autodesk\MapGuideStudio2007\FDO.
>>> There is an FDO folder for MgServer in C:\Program
>>> Files\Autodesk\MapGuideEnterprise2007\Server\Bin\FDO.
>>> Correct the above paths to your system.
>>> You must copy the OGRProvider.dll to both folders above, and edit the
>>> providers.xml in both folders.
>>> If you use MapGuide OS, it has recently shifted to FDO 3.2, and you
>>> have to change the version number in providers.xml.
>>> If you use MapGuide EP, you must build OGR provider, using an older FDO
>>> snapshot, otherwise it won't load.
>>> After restarting the service and studio, you should be able to select
>>> New -> Data connection...
>>> On the list you should now see "OSGeo FDO Provider for OGR"
>>> I hope you are working on windows, as you will have to compile a
>>> .dll/.so for both windows and linux otherwise.
>>>> Hi Kenneth and thank you for responding to this thread.
>>>> How do you edit the providers.xml?
>>>> It is my understanding that from the readme associated with the
>>>> ogr provider that I downloaded that you need to do 2 things:
>>>> 1, add an entry, this entry:
>>>> <FeatureProvider>
>>>> <Name>OSGeo.OGR.0.1</Name>
>>>> <DisplayName>FDO Provider for OGR</DisplayName>
>>>> <Description>Access to OGR data sources</Description>
>>>> <IsManaged>False</IsManaged>
>>>> <Version>0.1.0.0</Version>
>>>> <FeatureDataObjectsVersion>3.1.0.0</FeatureDataObjectsVersion>
>>>> <LibraryPath>OGRProvider.dll</LibraryPath>
>>>> </FeatureProvider>
>>>> to providers.xml and as you correctly stated, add the
>>>> OGRprover.dll into FDO.
>>>> I have done these and restarted the mapGuide service.
>>>> If all goes well, when you go to Studio and attempt to add a
>>>> database connection, you should the OGR provider. Right now, I
>>>> only see the ODBC connection that I set up awhile back.
>>>> Did I miss something?
>>>>> You must edit providers.xml and copy the dll into the FDO directory.
>>>>> This must be done in both the Service FDO folder and the Studio
>>>>> FDO folder.
>>>>> I'm guessing that Studio uses the GUI part, and the Service does the
>>>>> actual data access.
>>>>> Perhaps Studio should be modified to load this from the server?
>>>>> But then there would be windows/linux problems.
>>>>> I don't know how this works in Web Studio, if thats what you are trying.
>>>>>> Ok,
>>>>>> I know I have been a bit slower catching on to this than most,
>>>>>> largely because other extreme commitments but please bear
>>>>>> with me.
>>>>>> I just downloaded, unzipped and compiled OGR Provider with
>>>>>> PostGIS support so I can gain direct access to some of our
>>>>>> files using connections.
>>>>>> After adding an entry to providers.xml, I restarted service,
>>>>>> wen to studio and database connection but it isn't there.
>>>>>> What am I doing wrong?
>>>>>> Thanks very much in advance
>>>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
Type: image/pjpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060817/dae68652/ogr1.bin
More information about the Mapguide_users
