[mapguide-users] Insertation (reference) point of symbols
Ing. Cristian Galdini
galdini at dek.it
Tue Aug 29 03:45:26 EDT 2006
Hi, i have the same problem,
In my case, the server works fine as an application instead as a service (!)
from prompt "mgserver /interactive"
IBB Ingenieurbüro Battefeld wrote:
> Hi,
> all symbols has offset. It means, in the original drawing (dwg) the
> base point of each block (a simple circle) is the center point. But in
> the viewer each symbol seems to has an offset. The change of the
> reference point in MapGuide Studio is without effect. It's the same if
> I use dwg- or shp-format.
> What could be wrong?
> Thanks in advance - Peter
> P.s.: I'm using MapGuide Server 1.0.1.17812 and MapGuide Studio
> 1.0.0.17804
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
