[mapguide-users] Insertation (reference) point of symbols
Willem Schwarte willem at giskit.nl
Tue Aug 29 10:04:20 EDT 2006
I've had this problem too on Windows. On Linux everything is perfect aligned!
-----Oorspronkelijk bericht-----
Van: Ing. Cristian Galdini [mailto:galdini at dek.it]
Verzonden: dinsdag 29 augustus 2006 9:45
Aan: users at mapguide.osgeo.org
Onderwerp: Re: [mapguide-users] Insertation (reference) point of symbols
Hi, i have the same problem,
In my case, the server works fine as an application instead as a service (!)
from prompt "mgserver /interactive"
IBB Ingenieurbüro Battefeld wrote:
> Hi,
> all symbols has offset. It means, in the original drawing (dwg) the
> base point of each block (a simple circle) is the center point. But in
> the viewer each symbol seems to has an offset. The change of the
> reference point in MapGuide Studio is without effect. It's the same if
> I use dwg- or shp-format.
> What could be wrong?
> Thanks in advance - Peter
> P.s.: I'm using MapGuide Server 1.0.1.17812 and MapGuide Studio
> 1.0.0.17804
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
