[mapguide-users] Session has expired or is invalid. Please log in again.
Ivan Miličević
ivan at ineo.hr
Mon Dec 11 06:14:44 EST 2006
If the repository was copied across this would include the "Session"
repository which would no longer be valid because it is cleared every time
the server is restarted.
Is Ivan storing information in the "Session" repository that he wants to
persist? If so he needs to move it to the "Library" repository.
Bruce
_____
Sent: 11. prosinac 2006 12:00
Subject: RE: [mapguide-users] Session has expired or is invalid. Please log
in again.
Tražio sam mail ali nnisam mogao naći. Naći ću ja to sutra, sad mi vrijeme
curi
_____
Sent: 7. prosinac 2006 17:16
Subject: [mapguide-users] Session has expired or is invalid. Please log in
again.
i have a problem with the following error message:
Session has expired or is invalid. Please log in again. Exception occurred
in method MgSessionCache.GetSessionInfo at line 157 in file
c:\build_tux_area\mgdev_opensource\server\src\common\manager\SessionCache.cp
p
This error appears only when I try to navigate to the map from www (e.g.
www.mydomain.com/mapguide/mymap.aspx), i.e. everything works fine when I run
this site locally (e.g. http://localhost/mapguide/mymap.aspx).
Please help.
Thanks,
Kruno.
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061211/f7690c55/attachment.html
More information about the Mapguide_users
