[mapguide-users] Session has expired or is invalid. Please log in again.
Willem Schwarte
willem at giskit.nl
Mon Dec 11 06:21:30 EST 2006
Check your index file where you open the weblayout. You should set the URL to http://www.mydomain.com/mapguide/ instead of http://localhost/
Willem
Van: Ivan Miličević [mailto:ivan at ineo.hr]
Verzonden: maandag 11 december 2006 12:15
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] Session has expired or is invalid. Please log in again.
If the repository was copied across this would include the "Session" repository which would no longer be valid because it is cleared every time the server is restarted.
Is Ivan storing information in the "Session" repository that he wants to persist? If so he needs to move it to the "Library" repository.
Bruce
Sent: 11. prosinac 2006 12:00
Subject: RE: [mapguide-users] Session has expired or is invalid. Please log in again.
Tražio sam mail ali nnisam mogao naći. Naći ću ja to sutra, sad mi vrijeme curi
Sent: 7. prosinac 2006 17:16
Subject: [mapguide-users] Session has expired or is invalid. Please log in again.
i have a problem with the following error message:
Session has expired or is invalid. Please log in again. Exception occurred in method MgSessionCache.GetSessionInfo at line 157 in file c:\build_tux_area\mgdev_opensource\server\src\common\manager\SessionCache.cpp
This error appears only when I try to navigate to the map from www (e.g. www.mydomain.com/mapguide/mymap.aspx), i.e. everything works fine when I run this site locally (e.g. http://localhost/mapguide/mymap.aspx).
Please help.
Thanks,
Kruno.
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061211/5b2c5cc6/attachment.html
More information about the Mapguide_users
