[mapguide-users] PLEASE HELP ME AGAIN
sukalyan chakraborty
chakraborty.sarkar at gmail.com
Tue Jul 4 01:50:11 EDT 2006
Thank U The problem solved but now the little problem arising:
Resource was not found:
Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout
Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout Exception
occurred in method
Looking to this error i go for load the resource using
http://localhost/mapguide/mapadmin/login.php
& use user : Administrator &
Password : admin
now it gives the error
*Fatal error*: Call to undefined function MgInitializeWebTier() in *C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapadmin\login.php* on line
*68*
when i press the button to take entry in server.
Can U help me again? Please..
On 7/4/06, Ivan Miličević <ivan at ineo.hr> wrote:
> Copy wbconfig.ini from C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www directory to
> dotnetviewersample directory...
> *From:* sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
> *Sent:* 4. srpanj 2006 7:30
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] PLEASE HELP ME AGAIN
> Configuration file "C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\webconfig.ini"
> cannot be found or cannot be opened.Configuration file "C:\Program
> cannot be found or cannot be opened. Exception occured in method
> MgConfiguration.LoadConfiguration at line 108 in file
> c:\build_tux_area\mgdev\common\service\system\Configuration.cpp
> THIS IS THE NEW ERROR I'M FACING
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060704/9ef83821/attachment.html
More information about the Mapguide_users
