[mapguide-users] PLEASE HELP ME AGAIN
Ivan Miličević
ivan at ineo.hr
Tue Jul 4 03:39:59 EDT 2006
Hm... Did you download sheboygan.mgp? Download it from site and save mgp
file to C:\Program Files\MapGuideOpenSource\Server\Packages directory on
server.
Then goto http://localhost/mapguide/mapadmin/login.php logi in and clik on
Manage Packages. You shold see sheboygan.mgp in the list. Click on "load"
and then try again.
_____
From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
Sent: 4. srpanj 2006 7:50
Subject: Re: [mapguide-users] PLEASE HELP ME AGAIN
Thank U The problem solved but now the little problem arising:
Resource was not found:
Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout
Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout Exception
occurred in method
Looking to this error i go for load the resource using
& use user : Administrator &
Password : admin
now it gives the error
Fatal error: Call to undefined function MgInitializeWebTier() in C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapadmin\login.php on line
68
when i press the button to take entry in server.
Can U help me again? Please..
On 7/4/06, Ivan Miličević <ivan at ineo.hr> wrote:
Copy wbconfig.ini from C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www directory to
dotnetviewersample directory...
_____
Sent: 4. srpanj 2006 7:30
Subject: [mapguide-users] PLEASE HELP ME AGAIN
Configuration file "C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\webconfi
g.ini" cannot be found or cannot be opened.Configuration file "C:\Program
g.ini" cannot be found or cannot be opened. Exception occured in method
MgConfiguration.LoadConfiguration at line 108 in file
c:\build_tux_area\mgdev\common\service\system\Configuration.cpp
THIS IS THE NEW ERROR I'M FACING
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060704/9acd1275/attachment.html
More information about the Mapguide_users
