[mapguide-users] RE: RE: Now a new problem - ODBC connection error
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Jul 7 15:40:53 EDT 2006
Well, a simple work-around would be to not press the 'get' button and
just type in your value....What the name of the field that you're trying
to 'get' from? What's the name of the table? Do either have spaces in
the names?
Andrew
simflex wrote:
>Here is the original issue:
>Now a new problem. After successfully creating an odbc connection to an
>access db, I decided to group my some of my line layers like:
>Parcel1
>  ____ green
>  ____ red
>  ____ cyan, etc
>each representing a certain value.
>So, my expression is as follows:
>myplace ='Carrol'
>I click the "Get" button and I get the following error:
>"An exception occurred in FDO component.
>Identity Property must be a member of Property Collection."
>Any ideas what I may have mixed / messed up?
>I know you indicated that you had that problem and it went away.
>But given what I explained, first of all, do you think I am doing this
>right?
>I have been stuck on this now for over 2 weeks. I need serious help just to
>get beyond this stage.
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-4GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users mailing list
