[mapguide-users] RE: RE: Now a new problem - ODBC connection error
simflex simflex at millenniumhealthproducts.com
Fri Jul 7 15:52:47 EDT 2006
>>Well, a simple work-around would be to not press the 'get' button and just
type in your value
That was actually the initial approach I used.
the fieldname="the first value"
I kept doing it till all is done.
When I refreshed the map, I don't see the symbols representing each value on
the layer.
So, when I went back to verify that everything was done correctly, I got the
following error:
"This filter contains the following advanced element(s)
the named property is not available in this layer:
myplace:
Cannot leave advance mode until the expression is corrected"
BTW: myplace is a field name with several different values.
I use star as symbol with different colors to depict different value.
I then decided to use the "Get from" method which resulted in the error I
posted earlier.
View this message in context: http://www.nabble.com/RE%3A-Now-a-new-problem---ODBC-connection-error-tf1890181.html#a5223630
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide_users mailing list
