[mapguide-users] Cannot connect to MapGuide Server on local machine if no network connection available.
Luiz Marcio Viana
lmarcio at parsrio.com.br
Mon Jul 24 08:03:30 EDT 2006
Hi Jackie,
If you have problem using the localhost access, try install the Microsoft Loopback Adapter and set a real IP address to it.
This will create a local network for your computer.
Luiz Marcio
----- Original Message -----
Sent: Monday, July 24, 2006 1:22 AM
Subject: [mapguide-users] Cannot connect to MapGuide Server on local machine if no network connection available.
I've recently discovered a really nagging problem with the MapGuide Server being unreachable (both studio and viewer fail to connect to site server) if no network connection is available. Even when I am connecting to the server process from the same machine that it is running on! But the moment I plug in a network cable, everything's fine again!
Is there any way to resolve this problem?
Regards,
Jackie Ng
AEC Spatial Pty Ltd. / AEC Systems Pty Ltd.
SYDNEY - MELBOURNE - BRISBANE - PERTH - ADELAIDE - HOBART
A.B.N: 32 075 809 451
Level 4, 37-41 Prospect St. Box Hill, Victoria, 3128
Phone: 1300 368 609
Fax: 1300 362 140
www.aecsystems.com.au
jackie.ng at aecsystems.com.au
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060724/15d77e05/attachment.html
More information about the Mapguide_users
