[mapguide-users] Cannot connect to MapGuide Server on local machine if no network connection available.
Jackie Ng
jackie.ng at aecsystems.com.au
Mon Jul 24 21:33:09 EDT 2006
Hi Luiz,
I've tried this, but it still doesn't seem to work. Is there a specific IP
address/range I should be using?
@Willem: I've tried restarting the service when the machine is disconnected.
Still no good :(
Regards,
Jackie Ng
AEC Spatial Pty Ltd. / AEC Systems Pty Ltd.
SYDNEY - MELBOURNE - BRISBANE - PERTH - ADELAIDE - HOBART
A.B.N: 32 075 809 451
Level 4, 37-41 Prospect St. Box Hill, Victoria, 3128
Phone: 1300 368 609
Fax: 1300 362 140
www.aecsystems.com.au
_____
From: Luiz Marcio Viana [mailto:lmarcio at parsrio.com.br]
Sent: Monday, 24 July 2006 10:04 PM
Subject: Re: [mapguide-users] Cannot connect to MapGuide Server on local
Hi Jackie,
If you have problem using the localhost access, try install the Microsoft
Loopback Adapter and set a real IP address to it.
This will create a local network for your computer.
Luiz Marcio
----- Original Message -----
From: Jackie Ng <mailto:jackie.ng at aecsystems.com.au>
Sent: Monday, July 24, 2006 1:22 AM
Subject: [mapguide-users] Cannot connect to MapGuide Server on local machine
I've recently discovered a really nagging problem with the MapGuide Server
being unreachable (both studio and viewer fail to connect to site server) if
no network connection is available. Even when I am connecting to the server
process from the same machine that it is running on! But the moment I plug
in a network cable, everything's fine again!
Is there any way to resolve this problem?
Regards,
Jackie Ng
Phone: 1300 368 609
Fax: 1300 362 140
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060725/a8dbbbab/attachment.html
More information about the Mapguide_users
