[mapguide-users] Re: MGOS apps not loading
Dave Wilson dave.wilson at autodesk.com
Mon Jul 24 10:20:14 EDT 2006
If you are using Apache then there is a redirect for the ajaxviewer in
the httpd.conf file I believe. This needs to be changed from localhost
to your machine name or ip address. Search on localhost/mapguide and you
should find it.
Regards,
Dave
  _____
Sent: Monday, July 24, 2006 8:16 AM
Subject: [mapguide-users] Re: MGOS apps not loading
Hi Adam:
This sounds like the same problem I have posted on a couple of times ...
applications not loading.  While a browser refresh (or sometimes several
of them) will generally fix that session it's not very good for our
users.  We are using Windows Server 2003 with Apache/PHP standard MGOS
install.  I have not tested Autodesk MG Enterprise yet to see if this
problem got fixed there.  Sorry for no solution here.  I just wanted to
reiterate that we are having the same problem.
Bob Leeman
EIT (NL) Limited
20 Mercer's Drive
St. John's, NL   A1A 2X1
Canada
Tel: 709-738-1638
rleeman at eitnl.com   www.eitnl.com
	----- Original Message -----
	From: Adam Herbert <mailto:adam at aemsaustralia.com.au>
	Sent: Saturday, July 22, 2006 1:49 AM
	Subject: [mapguide-users] MGOS apps not loading
	Wondering if anyone has ever got the AJAX map viewer to load on
Windows 2003 IIS 6? I can load map viewer fine when browsing on the
local machine but when I access the same from a remote machine it has
the question marks and a blank map.
	Any suggestions would be greatly appreciated.
	Thanks.
	Adam Herbert
	IT Manager
	AEM Solutions Pty Ltd
	PO Box 514, Toowoomba Q. 4350
	Phone: 07 4613 0455
	Cell: 0437 599 907
	Website: www.aemsaustralia.com.au
<blocked::BLOCKED::http://www.aemsaustralia.com.au>
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060724/74132898/attachment.html
More information about the Mapguide_users mailing list
