[mapguide-users] Re: MGOS apps not loading
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Mon Jul 24 10:24:44 EDT 2006
I've got a similar problem, but with IIS. I've never been able to get
AJAX working....
Dave Wilson wrote:
> If you are using Apache then there is a redirect for the ajaxviewer in
> the httpd.conf file I believe. This needs to be changed from localhost
> to your machine name or ip address. Search on localhost/mapguide and
> you should find it.
> Regards,
> Dave
> *From:* Robert Leeman [mailto:rleeman at eitnl.com]
> *Sent:* Monday, July 24, 2006 8:16 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] Re: MGOS apps not loading
> Hi Adam:
> This sounds like the same problem I have posted on a couple of times
> ... applications not loading. While a browser refresh (or sometimes
> several of them) will generally fix that session it's not very good
> for our users. We are using Windows Server 2003
> with Apache/PHP standard MGOS install. I have not tested Autodesk MG
> Enterprise yet to see if this problem got fixed there. Sorry for no
> solution here. I just wanted to reiterate that we are having the same
> problem.
> Bob Leeman
> EIT (NL) Limited
> 20 Mercer's Drive
> St. John's, NL A1A 2X1
> Canada
> Tel: 709-738-1638
> rleeman at eitnl.com <mailto:rleeman at eitnl.com> www.eitnl.com
> <http://www.eitnl.com>
> ----- Original Message -----
> *From:* Adam Herbert <mailto:adam at aemsaustralia.com.au>
> *To:* users at mapguide.osgeo.org <mailto:users at mapguide.osgeo.org>
> *Sent:* Saturday, July 22, 2006 1:49 AM
> *Subject:* [mapguide-users] MGOS apps not loading
> Hi,
> Wondering if anyone has ever got the AJAX map viewer to load on
> Windows 2003 IIS 6? I can load map viewer fine when browsing on
> the local machine but when I access the same from a remote machine
> it has the question marks and a blank map.
> Any suggestions would be greatly appreciated.
> Thanks.
> **Adam Herbert***
> *IT Manager
> AEM Solutions Pty Ltd
> PO Box____ 514, Toowoomba Q. 4350
> Phone: 07 4613 0455
> Cell: 0437 599 907
> Website: www.aemsaustralia.com.au
> <blocked::BLOCKED::http://www.aemsaustralia.com.au>
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-4GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users
