[mapguide-users] Tooltip Issues in Internet Explorer
Alain Lebatard
alain.lebatard at autodesk.com
Fri Jun 2 12:55:06 EDT 2006
Hi Andy,
I opened your map, and I could see the problem with the tool tips. I
haven't look at the implementation but what I noticed is that the tool
tips holds still when they don't have an image attached. For example
parcels 25121.4901 or 25121.3101 displays "No image found" and stays on
the screen. The other parcels I've checked seem to have an image and
have the problem. That's not much, but maybe that will give you an
indication of where to look more specifically.
Alain
_____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, June 02, 2006 8:56 AM
Subject: [mapguide-users] Tooltip Issues in Internet Explorer
I have custom tooltips built in a map and as part of that tooltip, an
external page is called that generates an image. This works extremely
well in Firefox as well as the Studio preview window. However, in
Internet Explorer I get very odd, inconsistent results. These tooltips
sometimes work correctly, but most of the time, as you hover over a
parcel, it makes repeated calls to the server and never "holds still".
This looks an issue with AJAX handling between the two browsers.
Here is a link to try first in Firefox and then in IE:
http://mapguide.spatialgis.com/mapguide/mapviewerajax/?WEBLAYOUT=Library
%3a%2f%2fSpokaneMaps%2fWeb+Layouts%2ftest.WebLayout&USERNAME=Anonymous
<http://mapguide.spatialgis.com/mapguide/mapviewerajax/?WEBLAYOUT=Librar
y%3a%2f%2fSpokaneMaps%2fWeb+Layouts%2ftest.WebLayout&USERNAME=Anonymous>
Any help on this from Autodesk would be greatly appreciated. Thank you.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com <http://www.SpatialGIS.com>
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060602/d2063abb/attachment.html
More information about the Mapguide_users
