[mapguide-users] MG Opensource config issues
Andy Morsell amorsell at spatialgis.com
Thu Jun 15 18:16:24 EDT 2006
Kenny,
I saw your other message in the old Autodesk MapGuide group appealing for
help on this.  I am just totally swamped in project work right now or would
spend more time on this specific issue.  I generally hate to just brush off
questions like this, but a lot of these initial configuration and setup
snags have been discussed over and over in this list.  I'm sure we'll
collectively (somehow) put together an install and config FAQ or
troubleshooting guide and have it on the OSGEO Wiki, but for now, this list
is all we have.  I find it much easier to use this site for doing research
on previously discussed topics:
http://www.nabble.com/OSGeo-MapGuide-f14845.html
Andy
-----Original Message-----
From: kenny at keniginc.com [mailto:kenny at keniginc.com]
Sent: Thursday, June 15, 2006 10:41 AM
Subject: [mapguide-users] MG Opensource config issues
List,
in my earlier post here today, I indicated that I was having "Access Denied"
error when attempting to test the config settings.
After fiddling with it for a short while, I discovered that perhaps I was
having that problem because I installed it in windows xp, instead of windows
2003 server.
So, I installed it on windows 2003 server.
When I attempted to test with this:
http://localhost/mapguide/mapviewerajax/ajaxviewer.aspx?WEBLAYOUT=Library://
ATest.WebLayout
Instead of getting the error message on the manual which is this:
Resource was not found: Library://ATest.WebLayout
I got the following:
Compiler Error Message: CS0246: The type or namespace name 'OSGeo'
could not be found (are you missing a using directive or an assembly
reference?)
Source Error:
Line 21: <%@ Import Namespace="System.Text" %> Line 22: <%@ Import
Namespace="System.Web" %> Line 23: <%@ Import Namespace="OSGeo.MapGuide" %>
Line 24:
Line 25: <!-- #Include File="common.aspx -->
Source File: C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\mainframe.aspx
  Line: 23
Where did I go wrong?
Please help!!
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
