[mapguide-users] MG Opensource config issues
kenny at keniginc.com
Fri Jun 16 16:27:31 EDT 2006
list,
I have successfully installed a demo of the MG OS app and everything
seems to work real good.
I want to extend a special "Thank you" to Andy Morsell for not only
introduced Mapguide Open Source to me but also referred me to this
mailing list.
Yet, he continued to respond to my posts.
Thanks very much.
The only question I have ( for now :) ) is how do I replace the
Sheboygan.mgp file with my own shp / db files?
any suggestions, samples will be truly appreciated.
Quoting Andy Morsell <amorsell at spatialgis.com>:
> Kenny,
> I saw your other message in the old Autodesk MapGuide group appealing for
> help on this. I am just totally swamped in project work right now or would
> spend more time on this specific issue. I generally hate to just brush off
> questions like this, but a lot of these initial configuration and setup
> snags have been discussed over and over in this list. I'm sure we'll
> collectively (somehow) put together an install and config FAQ or
> troubleshooting guide and have it on the OSGEO Wiki, but for now, this list
> is all we have. I find it much easier to use this site for doing research
> on previously discussed topics:
> http://www.nabble.com/OSGeo-MapGuide-f14845.html
> Andy
> -----Original Message-----
> From: kenny at keniginc.com [mailto:kenny at keniginc.com]
> Sent: Thursday, June 15, 2006 10:41 AM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] MG Opensource config issues
> List,
> in my earlier post here today, I indicated that I was having "Access Denied"
> error when attempting to test the config settings.
> After fiddling with it for a short while, I discovered that perhaps I was
> having that problem because I installed it in windows xp, instead of windows
> 2003 server.
> So, I installed it on windows 2003 server.
> When I attempted to test with this:
> http://localhost/mapguide/mapviewerajax/ajaxviewer.aspx?WEBLAYOUT=Library://
> ATest.WebLayout
> Instead of getting the error message on the manual which is this:
> Resource was not found: Library://ATest.WebLayout
> I got the following:
> Compiler Error Message: CS0246: The type or namespace name 'OSGeo'
> could not be found (are you missing a using directive or an assembly
> reference?)
> Source Error:
> Line 21: <%@ Import Namespace="System.Text" %> Line 22: <%@ Import
> Namespace="System.Web" %> Line 23: <%@ Import Namespace="OSGeo.MapGuide" %>
> Line 24:
> Line 25: <!-- #Include File="common.aspx -->
> Source File: C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\mainframe.aspx
> Line: 23
> Where did I go wrong?
> Please help!!
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
