Make Check ... Stucks
Mandar Sarlashkar mann.sar at gmail.com
Sun Jun 18 23:49:23 EDT 2006
Dear Traian Stanev and Members of the list,
I followed your Instructions...
Now I am not getting the same error... About Java
BUT
When I run # make check
The execution hangs....  I am copying the text from command line...
make[4]: Leaving directory `/usr/local/mapguide-1.0.0
/Server/src/UnitTesting'
make[3]: Leaving directory `/usr/local/mapguide-1.0.0
Making check in Core
make[3]: Entering directory `/usr/local/mapguide-1.0.0/Server/src/Core'
make  check-TESTS
make[4]: Entering directory `/usr/local/mapguide-1.0.0/Server/src/Core'
GDAL_DATA=/usr/local/mapguide-1.0.0/Oem/gdal-1.3.0/data
PROJ_LIB=/usr/local/mapguide-1.0.0/Oem/proj-4.4.9/nad
Cursor keeps on blinking and after waiting for hours hours I had to
interrupt by pressing Ctl+C
make[4]: *** [check-TESTS] Interrupt
make[3]: *** [check-am] Interrupt
make[2]: *** [check-recursive] Interrupt
make[1]: *** [check-recursive] Interrupt
make: *** [check-recursive] Interrupt
[root at localhost mapguide-1.0.0]#
I am stuck and need some help...
Any suggestions are highly appreciated ... Let me know even If I have to
install Fedora again and follow some specific instructions...
Thanking you in advance...
Mandy
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060619/090e3ce0/attachment.html
More information about the Mapguide_users mailing list
