[mapguide-users] Make Check ... Stucks
Traian Stanev
traian.stanev at autodesk.com
Mon Jun 19 09:03:13 EDT 2006
What version of g++ are you using? We have seen it hang with g++ 4.0.0
on Fedora (happens in the Xerces library). The only fix I know for that
so far is to update to 4.0.2.
Traian
_____
From: Mandar Sarlashkar [mailto:mann.sar at gmail.com]
Sent: Sunday, June 18, 2006 11:49 PM
Subject: [mapguide-users] Make Check ... Stucks
Dear Traian Stanev and Members of the list,
I followed your Instructions...
Now I am not getting the same error... About Java
BUT
When I run # make check
The execution hangs.... I am copying the text from command line...
make[4]: Leaving directory
`/usr/local/mapguide-1.0.0/Server/src/UnitTesting'
make[3]: Leaving directory
Making check in Core
make[3]: Entering directory `/usr/local/mapguide-1.0.0/Server/src/Core'
make check-TESTS
make[4]: Entering directory `/usr/local/mapguide-1.0.0/Server/src/Core'
GDAL_DATA=/usr/local/mapguide-1.0.0/Oem/gdal-1.3.0/data
PROJ_LIB=/usr/local/mapguide-1.0.0/Oem/proj-4.4.9/nad
Cursor keeps on blinking and after waiting for hours hours I had to
interrupt by pressing Ctl+C
make[4]: *** [check-TESTS] Interrupt
make[3]: *** [check-am] Interrupt
make[2]: *** [check-recursive] Interrupt
make[1]: *** [check-recursive] Interrupt
make: *** [check-recursive] Interrupt
[root at localhost mapguide-1.0.0]#
I am stuck and need some help...
Any suggestions are highly appreciated ... Let me know even If I have to
install Fedora again and follow some specific instructions...
Thanking you in advance...
Mandy
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060619/d9989b63/attachment.html
More information about the Mapguide_users
