[mapguide-users] Compiling Mapguide and FDO on Debian
Traian Stanev traian.stanev at autodesk.com
Tue Jun 20 09:11:15 EDT 2006
I think sqlite3.a should have been compiled as part of this script. Can
you check if you have sqlite3.a somewhere under
./thirdparty/Sqlite3.1.5/linux/lib/? May be on Debian the name gets to
be something like libsqlite3.a, in which case the makefile will need to
be fixed. This is just a guess though.
Traian
  _____
From: Dpto proyectos OS [mailto:osgeo at srtec.com]
Sent: Tuesday, June 20, 2006 4:26 AM
Subject: [mapguide-users] Compiling Mapguide and FDO on Debian
Hi to all
I'm trying to compile from source FDO prior to installing Mapserver on a
Debian server.
I've installed everything needed as stated in manual, but in the
build_linux script I'm receiving failures on the Sqlite compilation,
claiming that:
Making all in thirdparty
make[1]: Entering directory `/usr/src/OpenSource_FDO/thirdparty'
Making all in Sqlite3.1.5
make[2]: Entering directory
`/usr/src/OpenSource_FDO/thirdparty/Sqlite3.1.5'
make[2]: *** No rule to make target `linux/lib/sqlite3.a', needed by
`all-am'.  Stop.
make[2]: Leaving directory
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/OpenSource_FDO/thirdparty'
make: *** [all-recursive] Error 1
Does anybody has found this problem before? there is some place where I
could find some info about this (there is no traffic on FDO mailing list
and I've tried to subscribe several times but I get no reply).
Thanks in advance
Pablo
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060620/451ae4e3/attachment.html
More information about the Mapguide_users mailing list
