[mapguide-users] Compiling Mapguide and FDO on Debian
Departamento de Sistemas
sistemas at srtec.com
Wed Jun 21 06:32:05 EDT 2006
Hi Traian
Thank you very much, this error has been bypassed using your solution,
but...
Now there is one extra step failing:
make[2]: *** No rule to make target `../Unmanaged/src/libFdo.la', needed
by `UnitTest'. Stop.
make[2]: Leaving directory `/home/alucas/OpenSource_FDO/fdo/unit_test'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/alucas/OpenSource_FDO/fdo'
make: *** [all-recursive] Error 1
While continuining the compilation for FDO prior to installing
mapguide... any hint on how to continue? there is not so many
documentation on the website for proceedings.
Does anybody has really been able to compile Mapguide on a Debian
Server?
I've seen that some distributions are LSB compliant so it would help or
either make packages LSB compliant or just to package them for other
distributions (our clients either por opensource or enterprise are using
SuSE and Debian servers, not Redhat)...
Multu mesc
Pablo
El mar, 20-06-2006 a las 09:11 -0400, Traian Stanev escribió:
> I think sqlite3.a should have been compiled as part of this script.
> Can you check if you have sqlite3.a somewhere
> under ./thirdparty/Sqlite3.1.5/linux/lib/? May be on Debian the name
> gets to be something like libsqlite3.a, in which case the makefile
> will need to be fixed. This is just a guess though.
> Traian
> ______________________________________________________________________
> From: Dpto proyectos OS [mailto:osgeo at srtec.com]
> Sent: Tuesday, June 20, 2006 4:26 AM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] Compiling Mapguide and FDO on Debian
> Hi to all
> I'm trying to compile from source FDO prior to installing Mapserver on
> a Debian server.
> I've installed everything needed as stated in manual, but in the
> build_linux script I'm receiving failures on the Sqlite compilation,
> claiming that:
> Making all in thirdparty
> make[1]: Entering directory `/usr/src/OpenSource_FDO/thirdparty'
> Making all in Sqlite3.1.5
> make[2]: Entering directory
> `/usr/src/OpenSource_FDO/thirdparty/Sqlite3.1.5'
> make[2]: *** No rule to make target `linux/lib/sqlite3.a', needed by
> `all-am'. Stop.
> make[1]: Leaving directory `/usr/src/OpenSource_FDO/thirdparty'
> Does anybody has found this problem before? there is some place where
> I could find some info about this (there is no traffic on FDO mailing
> list and I've tried to subscribe several times but I get no reply).
> Thanks in advance
> Pablo
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060621/74bcd397/attachment.html
More information about the Mapguide_users
