[mapguide-users] Loading own data
Dave Wilson
dave.wilson at autodesk.com
Wed Jun 21 15:35:13 EDT 2006
That will only work if your data was sampled in Lat Long.
Did your data have a .prj file included with it? If not can you find out
from the source what coordinate system it is in? This is critical if you
wish to merge data in a map.
Dave
-----Original Message-----
From: kenny at keniginc.com [mailto:kenny at keniginc.com]
Sent: Wednesday, June 21, 2006 1:32 PM
Subject: RE: [mapguide-users] Loading own data
I used the same coordinate system recommended by the manual which is
WGS84 datum, Latitude-Longitude; Degrees in the category of Lat Longs.
I figured since it worked the sample data, it should work for me.
Quoting Dave Wilson <dave.wilson at autodesk.com>:
> What coordinate system is your data in?
> Can you build a new map using your own data? That should tell you what
> coordinate system it is seeing if you didn't notice it had one from a
> .prj file.
> Otherwise you may need to reload your data and specify a coordinate
> sysetm if you don't have a .prj file.
> Dave
> Sent: Wednesday, June 21, 2006 12:57 PM
> Subject: [mapguide-users] Loading own data
> Hi list,
> sorry again for interrupting.
> Since I set up my OG OS, I am struggling to load our own data.
> I have followed the instructions on the "Getting Started" pdf file to
> load my own shapefiles. I added them to the existing Sheboygan layers
> but I don't see them draw on the map.
> Since most of you are beyond this level, can you please share with me
> what I might be doing wrong.
> I can see the layers but nothing happens when I uncheck sheboygan
> layers.
> I am so anxious to see my own data work.
> Thanks again in advance
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
