[mapguide-users] Loading own data
kenny at keniginc.com
Thu Jun 22 08:33:16 EDT 2006
Currently, we have a couple of mapguide apps running. The coordinate
system for one is in State Plane Georgia West NAD 83 US Feet
(GA83-w(GA83-W)) while the uses XY-FT (Arbitrary X-Y Coordinates) US
Survey.
And of course the one I posted in Lat Longs category.
So, not real sure what I need to do to resolve this.
Thanks any and all help.
Quoting Dave Wilson <dave.wilson at autodesk.com>:
> That will only work if your data was sampled in Lat Long.
> Did your data have a .prj file included with it? If not can you find out
> from the source what coordinate system it is in? This is critical if you
> wish to merge data in a map.
> Dave
> -----Original Message-----
> From: kenny at keniginc.com [mailto:kenny at keniginc.com]
> Sent: Wednesday, June 21, 2006 1:32 PM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] Loading own data
> I used the same coordinate system recommended by the manual which is
> WGS84 datum, Latitude-Longitude; Degrees in the category of Lat Longs.
> I figured since it worked the sample data, it should work for me.
>> What coordinate system is your data in?
>> Can you build a new map using your own data? That should tell you what
>> coordinate system it is seeing if you didn't notice it had one from a
>> .prj file.
>> Otherwise you may need to reload your data and specify a coordinate
>> sysetm if you don't have a .prj file.
>> Dave
>> Sent: Wednesday, June 21, 2006 12:57 PM
>> Subject: [mapguide-users] Loading own data
>> Hi list,
>> sorry again for interrupting.
>> Since I set up my OG OS, I am struggling to load our own data.
>> I have followed the instructions on the "Getting Started" pdf file to
>> load my own shapefiles. I added them to the existing Sheboygan layers
>> but I don't see them draw on the map.
>> Since most of you are beyond this level, can you please share with me
>> what I might be doing wrong.
>> I can see the layers but nothing happens when I uncheck sheboygan
>> layers.
>> I am so anxious to see my own data work.
>> Thanks again in advance
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
