[mapguide-users] mapviewerdwf stopped working....
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Jun 28 15:34:08 EDT 2006
I tried that. I acutally already had version 7 installed. I tried taking
it off and reinstalling that (as well as the ActiveX control)....no
change. Right now, I'm trying everything once more...only this time, I'm
taking off EVERYTHING (including Studio) and am going to check the
registry for any remnants before reinstalling. As a result, I don't have
that index.htm file at the moment, but you'd have a copy of it in that
same folder. It's not a custom file...
Andrew
Walt Welton-Lair wrote:
> Are you using DWF Viewer 6 or 7?  Version 7 just became available
> recently, and you should be using it.
> If you were already using DWF Viewer 7 try reinstalling it.
> Also, what method is it trying to call on line 14 of index.htm?
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Wednesday, June 28, 2006 3:15 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] mapviewerdwf stopped working....
> I take it back...AJAX isn't working either. Though, at least with the
> AJAX viewer, I can see my project. I just can't select anything.
> Andrew
> Andrew DeMerchant wrote:
>> I'm not sure what's going on here, but my DWF map viewer seems to
>> have stopped working. I've tried removing and reinstalling MGS and
>> MGSE, but to no avail. My problem remains (see the attached image).
>> The AJAX viewer still works fine. One interesting thing to note is
>> that the DWF viewer  doesn't seem to be asking me to log in anymore
>> (it always used to). AJAX asks me to log in. I wonder if it's some
>> sort of security thing that's causing the problem? Any ideas?
>> Andrew
>> 	*Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-4GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>>To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>For additional commands, e-mail: users-help at mapguide.osgeo.org
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users mailing list
