[mapguide-users] mapviewerdwf stopped working....
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed Jun 28 16:15:59 EDT 2006
For the record, I managed to fix this problem....in the end, the only
thing that worked was a total uninstall of everything MapServer related
(Studio, DWF Viewer, etc) and a cleaning of the registry of any residual
settings. I'd be will to bet that all that I really needed to do was
uninstall DWF Viewer, and wipe out the left-over reg settings (DWF
Viewer and Studio both had some left overs in the registry). I've got a
new problem now, but I'll post that seperately.
Andrew
Andrew DeMerchant wrote:
> I tried that. I acutally already had version 7 installed. I tried
> taking it off and reinstalling that (as well as the ActiveX
> control)....no change. Right now, I'm trying everything once
> more...only this time, I'm taking off EVERYTHING (including Studio)
> and am going to check the registry for any remnants before
> reinstalling. As a result, I don't have that index.htm file at the
> moment, but you'd have a copy of it in that same folder. It's not a
> custom file...
> Andrew
> Walt Welton-Lair wrote:
>> Are you using DWF Viewer 6 or 7? Version 7 just became available
>> recently, and you should be using it.
>> If you were already using DWF Viewer 7 try reinstalling it.
>> Also, what method is it trying to call on line 14 of index.htm?
>> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
>> *Sent:* Wednesday, June 28, 2006 3:15 PM
>> *To:* users at mapguide.osgeo.org
>> *Subject:* Re: [mapguide-users] mapviewerdwf stopped working....
>> I take it back...AJAX isn't working either. Though, at least with the
>> AJAX viewer, I can see my project. I just can't select anything.
>> Andrew
>>> I'm not sure what's going on here, but my DWF map viewer seems to
>>> have stopped working. I've tried removing and reinstalling MGS and
>>> MGSE, but to no avail. My problem remains (see the attached image).
>>> The AJAX viewer still works fine. One interesting thing to note is
>>> that the DWF viewer doesn't seem to be asking me to log in anymore
>>> (it always used to). AJAX asks me to log in. I wonder if it's some
>>> sort of security thing that's causing the problem? Any ideas?
>>> Andrew
>>> *Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.1-877-4GEMTEC x.163
>>> fax 506-453-9470
>>> /GEMTEC Limited <http://www.gemtec.ca>
>>> /191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>>>To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>>For additional commands, e-mail: users-help at mapguide.osgeo.org
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users
