DWF Viewer 7
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Wed Jun 28 15:44:01 EDT 2006
If you use DWF Viewer with MapGuide you should make sure you're using
version 7.  It was just released, and includes some fixes relevant to
MapGuide.  These include:
- fixed ActiveX control activation issues (see info on KB912945 at
http://support.microsoft.com/kb/912945/en-us)
- fixed a stream error if you have many layers or a layer with many
themes ("Unrecognized or unexpected sequence in stream")
- OnSelectionChanged event is only raised when the selection set
actually changes
- layer/legend control now displays a layer group even if all its
children are hidden
- updated icons in the layer/legend control
You can get the updated viewer at http://www.autodesk.com/dwf.
Walt
 W       E         @__   __o
   A   T   R   @___    _ \<,_
     L           @_   (*)/ (*)
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060628/948cbaf8/attachment.html
More information about the Mapguide_users
