[mapguide-users] Layer Groupings, Andy can you help?
kenny at keniginc.com
Thu Jun 29 22:33:44 EDT 2006
Thanks Andy / Andrew.
Just looking at the screenshot you attached, I can understand why I
couldn't find it. I could only see something like:
Add A Scale Range Duplicate. The rest are grayed out. Please see attached.
Where should I be looking for when looking for Add a rule, etc?
Quoting Andrew DeMerchant <andrew.demerchant at gemtec.ca>:
> It's in that winmail.dat file....he must be using Outlook, and you must
> not be (neither am I). Check out this page for the solution:
> http://www.gpc.edu/~jbenson/resource/winmail.htm
> Making those themed layers really isn't too complex though. I'd offer
> you some help right now, but I'm home for the night, and don't have
> Studio in front of me.
> Andrew
> kenny at keniginc.com wrote:
>> Thanks a lot, Andy.
>> I am going over the gettingStarted pdf file as I write this.
>> Visually, it would have been great to see the attachment you
>> mentioned. It apparently didn't come through.
>> Quoting Andy Morsell <amorsell at spatialgis.com>:
>>> Those are standard thematic layers created in Studio when defining
>>> the layer
>>> style. Attached is a screenshot. There is also an example in the
>>> GettingStartedGuide.pdf that is in the Studio Help folder. You can also
>>> open and examine in Studio the Parcels layer definition, which is
>>> themed, in
>>> your Sheboygan sample dataset.
>>> Andy
>>> -----Original Message-----
>>> From: kenny at keniginc.com [mailto:kenny at keniginc.com]
>>> Sent: Thursday, June 29, 2006 1:27 PM
>>> To: users at mapguide.osgeo.org
>>> Subject: [mapguide-users] Layer Groupings, Andy can you help?
>>> Andy, I see you that you get picked on a lot around here for obvious
>>> reasons. Sorry for joining that group.
>>> Reason, I am singled you out is I saw on your sampe MG OS app that you
>>> grouped Roads into Major and Minor categories.
>>> Did you do this programmatically or did you do it through the Studio?
>>> Obviously, for me at this stage, I would prefer to do things through the
>>> studio until I am very knowledgeable about the architecture.
>>> From what I have read, you use themes to accomplish this but how do I do
>>> this?
>>> For instance, I have basins that need to be grouped into several
>>> sub layers,
>>> each with same view extent.
>>> Any assistance, including any materials that would make this easy.
>>> Thanks for getting me started on MG OS.
>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
Type: image/pjpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060629/1755d75b/layerGroupings.bin
More information about the Mapguide_users
