[mapguide-users] Layer Groupings, Andy can you help?
kenny at keniginc.com
Fri Jun 30 11:29:32 EDT 2006
Thank you, I got it!
Pictures can, and do tell a thousands compelling stories.
Just showing the two screenshots convinced me that no additional
configurations were needed.
I had to focus on trying to figure out why I could not see any of the buttons.
Evidently, since I was logging into our server via the remote desktop
connections, the screen got compressed and some icons, including the
button was hidden.
I played around till I found an edge and dragged it to the left to
make the button visible.
Special "thank you" to all that contributed.
Quoting Andrew DeMerchant <andrew.demerchant at gemtec.ca>:
> If you don't see a theme button, you likely already have your layer set
> as a themed layer (you'd have a 'reset to basic' button). I've
> attached 2 screen shots. The first (theme.jpg) is with the theme button
> (for a normal, basic layer). The second is what it looks like once your
> pressed the theme button.
> Andrew
> kenny at keniginc.com wrote:
>> ouch, I can't find the response I got from Jason.
>> Guys, can any of you guys give me likely scenarios why I could not
>> find a screen similar to the screenshot attached by Andy?
>> According to Jason Birch, it is supposed to be to the far of the
>> screenshot I attached.
>> On that screen, I see Add a scale Range, Duplicate, Delete, Move
>> Up, and Move Down arrows, nothing else.
>> Further down, I see, 0 - Infinity: Area, or point or line
>> Last line at the bottom says: Style of Geometry and Feature Label.
>> Could there be any possible reason why I can't see a Theme button?
>> Quoting Andy Morsell <amorsell at spatialgis.com>:
>>> I used Snagit to grab the screenshot, copy to the clipboard and then paste
>>> to the Outlook email. That was probably the problem. Here it is attached
>>> as a JPG file instead.
>>> Andy
>>> -----Original Message-----
>>> From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
>>> Sent: Thursday, June 29, 2006 5:33 PM
>>> To: users at mapguide.osgeo.org
>>> Subject: Re: [mapguide-users] Layer Groupings, Andy can you help?
>>> It's in that winmail.dat file....he must be using Outlook, and you must not
>>> be (neither am I). Check out this page for the solution:
>>> http://www.gpc.edu/~jbenson/resource/winmail.htm
>>> Making those themed layers really isn't too complex though. I'd offer you
>>> some help right now, but I'm home for the night, and don't have Studio in
>>> front of me.
>>> Andrew
>>>> Thanks a lot, Andy.
>>>> I am going over the gettingStarted pdf file as I write this.
>>>> Visually, it would have been great to see the attachment you
>>>> mentioned. It apparently didn't come through.
>>>>> Those are standard thematic layers created in Studio when defining
>>>>> the layer style. Attached is a screenshot. There is also an example
>>>>> in the GettingStartedGuide.pdf that is in the Studio Help folder.
>>>>> You can also open and examine in Studio the Parcels layer definition,
>>>>> which is themed, in your Sheboygan sample dataset.
>>>>> Andy
>>>>> From: kenny at keniginc.com [mailto:kenny at keniginc.com]
>>>>> Sent: Thursday, June 29, 2006 1:27 PM
>>>>> Subject: [mapguide-users] Layer Groupings, Andy can you help?
>>>>> Andy, I see you that you get picked on a lot around here for obvious
>>>>> reasons. Sorry for joining that group.
>>>>> Reason, I am singled you out is I saw on your sampe MG OS app that
>>>>> you grouped Roads into Major and Minor categories.
>>>>> Did you do this programmatically or did you do it through the Studio?
>>>>> Obviously, for me at this stage, I would prefer to do things through
>>>>> the studio until I am very knowledgeable about the architecture.
>>>>> From what I have read, you use themes to accomplish this but how do
>>>>> I do this?
>>>>> For instance, I have basins that need to be grouped into several sub
>>>>> layers, each with same view extent.
>>>>> Any assistance, including any materials that would make this easy.
>>>>> Thanks for getting me started on MG OS.
>>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-4GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
More information about the Mapguide_users
