[mapguide-users] FW: dotnetviewersample does not work!
Andy Morsell
amorsell at spatialgis.com
Fri Mar 10 17:54:03 EST 2006
Steven,
Did you see the InstallMapGuideSamples.pdf file on the osgeo web site? A
few things that might cause your problems:
Are you using .NET 2.0?
Did you create a bin folder and copy the MapGuideDotNetApi.dll and
MapGuideUnmanagedApi.dll from the /mapviewernet/bin folder?
Did you copy the webconfig.ini file from the /www folder to the
/dotnetviewersample folder?
You will also find that the sample app is in C# (my preference), rather than
VB, but translation should not be hard.
You're in Stateline? I went to college at Nevada - Reno and spent quite a
bit of time in Stateline. In fact, my wife was born there. It's a
fantastic area. For those who haven't been, go see Lake Tahoe.......
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
From: Robert Bray [mailto:robert.bray at autodesk.com]
Sent: Friday, March 10, 2006 2:41 PM
Subject: [mapguide-users] FW: dotnetviewersample does not work!
Posting to the users list.
_____
From: Steven J Reed [mailto:sjreed at edcomputing.com]
Sent: Friday, March 10, 2006 3:38 PM
To: robertbray at osgeo.org
Subject: dotnetviewersample does not work!
Robert,
I have downloaded this file and unzipped it into it's own folder (C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewerasmple). When
I attempt to execute it via
http://localhost/mapguide/dotnetviewersample/ajaxtiledviewersample.aspx I
get a Compilation Error telling me the OSGeo.MapGuide namespace could not be
found.
Am I missing something???
When I downloaded this, I expected to see a complete VS.Net solution. I
also expected some kind of readme file telling me what I should be doing to
actually run this. Not seeing any of that, I used the 'Getting Started'
framework as an example of what to do.
I am embarking on a major MapGuide development and decided to go with the
'new' MapGuide instead of continuing with 6.5. Since I'm planning on using
VB.Net, I figured this example would be a good starting point.
Thanks in advanced for your assistance.
.Steve
_____________________________
Steven J. Reed
El Dorado Computing
P. O. Box 5745
Stateline, NV 89449-5745
(775) 589-6850 (916) 226-9065 Fax: (503) 218-7622
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060310/e72d024b/attachment.html
More information about the Mapguide_users
